ticki2
Apr 22, 2014Explorer
If there are no apparent water leaks anywhere it is most likely the suction line between water tank and pump causing an air leak . Sometimes just tightening the fittings or hose clamps will fix the problem . Sometimes it needs a new hose . it can also be the pump internal check valve . Good luck
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
