BTPO1
Apr 22, 2014Explorer
Itchey Feet wrote:
Most likly just leaking back thru the pump, happens a lot -- just turn off the pump switch till needing water --- will save on battery as you are not needing water 24-7. KMHO
I agree with the check valve in the pump leaking through allowing the pressure to drop thereby starting the pump. Mine leaked, I replaced it. A few weeks later it leaked through again. Now I just turn off the pump unless I need it. I do have to close the suction (Inlet) valve to the pump though or the fresh water tank will fill and overflow if hooked up to city water. JMO
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
