donn0128
Mar 14, 2016Explorer II
Very generally speaking you will not get a good HD signal routing thru the crappy coax and cheap splitters found in most RVs. You can test it, but dont be surprised.......
As a test, setup using a known good coax from dish directly to reciever. Get a good signal, then connect thru the sat in on the side of your RV. Signal? Or no signal?
