wa8yxm
Mar 21, 2016Explorer III
If you are hooking to the jack next to the green light, you will get no signal
you have to pull the plate, on teh back should be 3 coax cables, the one in the middle, disconnect it, extend it to the receiver using a double female connector and some more cable, and see if that works.
or better yet, run nice new clean RG-6 to the outside from the receiver.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
