rexmitchell
Mar 21, 2016Explorer
wa8yxm wrote:
If you are hooking to the jack next to the green light, you will get no signal
you have to pull the plate, on teh back should be 3 coax cables, the one in the middle, disconnect it, extend it to the receiver using a double female connector and some more cable, and see if that works.
or better yet, run nice new clean RG-6 to the outside from the receiver.
Thanks, I'll keep this in mind.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
