NinerBikes
Mar 04, 2016Explorer
Up to about 360 watts or 30 amps, 12 volts and a PWM controller is better. Those would be 12 V panels, and you be concerned about what the lsc or amperage during short circuit reading is, the higher the better. 18V under max load is good, 17.0V under max load would be better, the amperage rating would be higher. This is all for 12 Volt rated panels. I'd also insist on Poly crystalline panels, not mono panels.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
