time2roll
Mar 05, 2016Nomad
Voc may climb a bit higher than 108 in cold temperatures but should not exceed the 150v controller rating.
Use the string calculator to verify voltages and compatibility.
http://string-calculator.morningstarcorp.com/
If one panel is shaded the bypass diodes may cut the voltage 1 or 2 volts from the rest but the power still flows through just fine.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
