carl2591
Mar 05, 2016Explorer III
thanks mexicowander... that is quite graphic of the skull there.. :)
so I went to morningstar string calaculator and man the terms they through out ..
so when i put in the grape 195 watt panels and teh 45 amp mppt tristar controller it show me this:
Configuration
1 Module in Series Per String
3 Strings in Parallel
585 Watts Total
Optimal Configuration
SO what does that mean.. what is the difference between a module and a string.
the way i interpret this is for one 45 amp mppt controller I can use 3 195 watt panels in parallel for a total of 585 watts.
what does the "1 Module in Series Per String" mean?? i wish the term would be more consistent in the industry.
to all the input thanks for the help. this is quite confusing till you GET IT..
Configuration
585 Watts Total
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
