time2roll
Mar 05, 2016Nomad
I put in 0°C and Voc warns it is very close to 150 maximum at 148.44 volts.
If you put in lower, the calculator may have said to go parallel because Voc rises as temperature drops.
Alternative controller is MidNite Solar 200 (Vmax 200 volts) and then you are pushing $700.
www.solarblvd.com MidNight 200
Shop around
Voltage will tend to be closer to Vmp while in use. I would probably chance it with the lower cost Tristar. Could always cover one panel in winter.
Shop around
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
