carl2591
Mar 06, 2016Explorer III
the string calculator I used did not "say" which controller to go with you pick from a drop down box and i used the MPPT 45 amp TriStar model.
In doing that it show what I copied above, that three strings in one module would work fine. that is what i think would be the best solution for me and these panels.
the 235 watt 60 cells are like $325 bucks each.. the 195 watt panels are $195 dollars which save me $125 per panel x 3= $375 which will almost buys the 45amp mppt controller at $420, and thanks for the link to that..
I may mount them in a way they can be tilted if needed as well.
thanks for all the info.
smkettner wrote:
Try Grape Solar 235w 60 cell panels in the string calculator.
It will say to go with MPPT-60 but I don't think it is needed flat on the roof.
The 45 is fine even though the nominal wattage exceeds the recommended maximum.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
