dewey02
Jan 26, 2016Explorer II
RnTBnB wrote:
What setup would I need in order to be able to run a fan in the bedroom all night and a coffee maker the next morning?
Just trying to give some alternatives.
As someone has already said, you can make coffee via a percolator on the stove.
As for fans, you don't even need to plug into your house batteries if you don't want to. We use two of these (one in each bedroom window). They will run for a couple of nights on 8 D-cells. They have a hook that you can hang them right in the window. They don't create a huge breeze, but enough to continually bring cooler outside air into the camper. They are 12 volt, so they can run on the D-cells, or run on your house battery, and they come with an adapter so you can run them on A/C when you have access to power.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
