Butch50
Jan 08, 2018Explorer
Questions about running generator in back of truck
I plan on carrying my Yamaha 3000iSEB in the bed of my truck. It will be in the front of the bed behind the cab. Is anyone using their generator where they could get wet while running or just driving down the road? If so are you having any problems with them because of it?
I planing on having some Diamond plate bent to fit under and behind the generator and then come across the top with some bent down bit on the front and sides a little to give it some protection. It would be mostly open on the front and sides for air circulation and heat.
In the past I mostly have had built in generators but with my 5th it is not designed for an on board generator so I have to do it some other way.
I know get solar and leave the generator home. I already own the generator so my only expense would be the Diamond plate.
Thanks
Thanks
