2oldman
Jul 01, 2019Explorer II
phemens wrote:How do you 'turn off' the charger? When I went whole-house I installed an spst switch for the converter 120v power.
However, if I leave breakers on, but turn off power to the Boondocker converter/charger, I lose power to the refrigerator
Your 12v appliances should never lose power simply if the charger is off...unless you've messed with the wiring. That means you could never boondock.
Rest of it sounds good.. especially the Li. Did you consider going higher voltage?
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
