profdant139
Mar 03, 2019Explorer III
Rice, the hose run had a little uphill portion -- a few inches -- and forty feet of hose. Apparently, the cumulative weight of the water in the line created back-pressure on the fixture that attached to the tank valve. The Sewer Solution fixture failed catastrophically.
So that is why I am hesitant about Flojet -- will it do the same thing? The responses above indicate that it will be able to handle the task. The difference, as wa8yxm mentioned, is that the Sewer Solution was powered by the pressure of the incoming water overcoming the back pressure of the outgoing water. Flojet has a pump, instead.
