RJsfishin
May 04, 2015Explorer
Like another said, if reigniting is the only problem, let the temp rise to a tolerable level, then ignite it w/ a propane lighter. Set the temp control to the coldest setting, and it will run for several several hours to bring temp way down again. You maybe have to do this only once.....maybe twice a day.
In a really tight spot, I can always make a fridge run by hot wiring the gas valve, and ignite w/ a lighter.
I also have a finiky Norcold, and I just make the best of it.
Ain't it amazing tho, we can get to the moon.....even Mars, no problem, but we can't make a dam fridge to work at 6K elev !!
