DrewE
Feb 13, 2016Explorer III
evy wrote:
I was planning on getting a Powerhouse PH2100PRi, 2100watts it's rated at 16.7amp, is that ok?
That should be just fine for any converter, and will power your microwave as well. It may well struggle a little doing both at the same time when the converter is under load (charging the batteries). It looks like a reasonable generator choice to me. (It won't reliably run a standard RV rooftop air conditioner, though two with the parallel kit should do that handily. It might possibly run a little portable or window-mount AC.)
I trust that you've planned and left room to properly vent the fridge (as per the instructions from Dometic).
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
