time2roll
Feb 13, 2016Nomad
evy wrote:
I found this on the net, you think it's going to be an issue?
Convection microwave specs
That microwave requires 1500 watts input. Really need a 2000 watt inverter or 2000 watt generator to run it.
If you plan to run on inverter that will be a very large draw. I would look at Panasonic inverter microwaves. These actually reduce power input when a lower power setting is chosen. Input power may drop to 500/700 watts on the lowest setting. The GE would just cycle on/off at the 1500 watt level.
The lower the draw the more energy you will get out of the battery. If you will be using this daily I recommend 4 batteries. Keep in mind only about half of the battery energy will get to the actual food. Still need to replace 105% of the energy back to the battery.
Panasonic on Amazon
Panasonic
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
