JiminDenver
Oct 30, 2013Explorer II
Like MPG ratings for cars, the rated specs on a panel is something most will never see. This is just a way for them to give us realistic expectations and not send the panels back because they don't put out rated levels.
I spent the weekend staring at either a DVM or a thermometer taped to the back of my panel. It was the high 60's and the highest I saw was 120 f or 48,89 c. Since my panels track the sun there isn't much I can do. If I change the tilt and get a lower temp, I loose amps.
My biggest decrease in output was going from the mid 80s to the 90s, from the 90s to 120 did drop output some but only a tenth of a amp.
BTW if you are checking for short circuit amps on a cheap meter, do it fast. Those leads get hot quickly.
