BFL13
Oct 30, 2013Explorer II
I can see it if Ken meant that using MPPT with a 12v panel isn't worth it, but I am not clear on the question whether a single 240 and MPPT is superior in some way to two 120s in series and MPPT. (ASSuming the series wire is not a problem)
The other test did show that you needed fatter wire from two 120s in parallel than from two 120s in series. I am unclear if the test showed, given the fatter wire, you would do better with one or the other and MPPT.
