JiminDenver
Oct 31, 2013Explorer II
BFL
Between the low temp and the high temp there was only a half a volt difference in IMP, and less than a amp in MPPT. In the real world it isn't enough to make or break a system. Either you have enough solar or you don't.
Is MPPT worth it? Hard to tell with the prices like they are. The cost comparison was close until I saw a 200w kit selling for $300 shipped. I can't build a 24v system for that, it's at least $400. The extra $100 would get you a extra 30w if it was needed.
In a case where you had two 100w panels the money would be better spent on a third panel rather than a Eco-worthy controller. you would get more out of the investment.
Have a roof maxed out with panels and need a few extra amps, then a MPPT makes sense.
For a person setting up a mounted system, find the panels that fit the best and then figure out what controller to use.
