westend
Nov 26, 2016Explorer
MarkLDN wrote:
Haha Complete Novice.
I have my Haynes manual to hand and have consulted numerous forums (such as this one) on how to conduct a thorough flush. Though I get nervous when something doesn't go to plan, or something unexpected happens. The last thing I want to do is break something and have to take it to the shop. The whole reason I am doing it myself is to save on shop labour (currently off work so plenty of free time).
The reason for the flush is that I noticed a drop in my coolant level and saw indications of a leak. As I had to drain the system anyway I wanted to give it a proper flush/chem clean and put new coolant in. Replaced the thermostat while I was at it. So the answer is I am probably paranoid because nothing was wrong with the system before I took it all apart.
Putting new coolant in now very slowly. The reason I dont think the thermostat is opening is because I can normally see the coolant flow towards the upper rad hose (through the open cap) and feel the hose itself get hot. Only hoses that are getting hot are the heater core hoses at the moment.
I have topped it up with 3 gallons and currently letting it cool to try a final fill up before putting the cap on and taking it for a test drive.
Very much appreciate your words of wisdom and patience with my posts!
Mark
Mark,
I applaud your efforts to get the Haynes manual and work your way through the flush process. I have customers that want to maintain their equipment and vehicles. I tell every one of them to buy a Haynes manual and do some reading before breaking out the tools.
The manuals can be worded towards a more generic instruction set so some vehicles that have inherent air entrapment need to be treated differently than those with common cooling systems. I have a BMW, for instance, that is somewhat difficult to get the air out of the head and upper coolant plumbing. My Ford truck is totally different. Pour in antifreeze and go with the truck. Your van is probably more alike to the truck.
You may not feel the upper radiator hose getting extremely warm right away. You will definitely know with a test drive if your system is full and the thermostat is opening. Without a full system, the van engine will get very hot, even overheat. Don't worry about it if you have filled the radiator a couple of times. Any trapped air will be expunged by the water pump and your system should be full.
Good luck with your radiator.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
