Gjac
Nov 27, 2016Explorer III
MarkLDN wrote:. What I do is remove the lower hose from the radiator, remove the thermostat and reinstall the housing then insert a garden hose into the lower hose and force water though the entire system. I made a section of hose that fits tightly into the radiator hose then clamp with a hose clamp. By removing the thermostat you allow water to pass through the block. I also set the dash to heat to flush out heater core. When I first did this after using the Prestone Flush I was amazed at how much more stuff came out of the system.
Wondering where best to place the hose to flush that part of the engine block out.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
