MarkLDN
Nov 28, 2016Explorer
time2roll wrote:
Yes it will overflow as the air bubble expands due to rise in temperature.
All you can do is attempt to catch the overflow. When the thermostat opens the radiator will seem to go empty. Keep topping off for 5 to 10 additional minutes.
I assume you have a coolant recovery bottle. This will chase any remaining air out of the system during the first few heating and cooling cycles.
I have always thought about drilling a 1/16" or 1/8" hole in the flange but have never tried it. Can't see that it would hurt much. Could go down and ask for a premium thermostat and see if it has the release hole. Or possibly remove the thermostat during the initial fill to that level. Still need to observe the thermostat open and verify the level before you roll.
No idea why it shut off.
Did you have the old thermostat in during chem clean? Probably had the release valve. Dig it out of the trash and inspect.
Thank you sir.
Yup, it's got an overflow reservoir.
So that's what they meant when they asked if I wanted basic or premium! Last time I was given the option in a part there wasnt any difference other than "lifetime" or "1 year" warranty. The parts person didnt know what they were talking about as I queried this again and they had no answer.
But certain old one didnt have a release valve. I held them up against eachother. The garbage man has taken it to a better place now though so can't double check.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
