time2roll
Nov 28, 2016Nomad
Any chance the old thermostat was stuck partially open? Probably all is normal once the air bubble is chased out. Engine may have effectively been running cold for a while. Seen this plenty of times. Temperature gauge should rise steadily but may read higher than you are used to. DO NOT EVER open the cap if the hoses are stiff with pressure, let the engine cool.
I understand the best thermostats are all brass and called "balanced sleeve"
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
