GlennLever's avatar
GlennLever
Radiator Coolant Fan Runs All The Time
Noticed my hydraulic radiator fan is running all the time.
Gillig tells me that there is a sensor to control the fan solenoid.
Gillig sent me a circuit diagram for a 1994 bus with rear battery box an run box (I am a 1996 chassis for a 1997 Motor Home)
The color codes on the wires at the fan solenoid are not correct.
If I feed 12V and ground to the fan solenoid the fan slows down right away, remove the 12 v and it speeds up.
This is the fan solenoid
It control hydraulic pressure to the fan
Gillig supplied the sensor location.
Wire color codes are correct here. But the wires leading into the harness at the fan solenoid are different.
If I supply 12v to the yellow and ground to the black nothing happens.
Ok, I have heard back from Gillig with a new diagram.
Color codes on this diagram are correct.
There is an additional sensor between the coolant temperature sensor and the fan solenoid. (Air Inlet Fan Temp REF 51-15885-000)
I have asked the parts guy, Rick, to give me the location of this sensor, and part availability?
I suspect that as a temporary fix I could tie the Yellow and Red wires running into the Air Inlet Fan Temp together (no cutting, I have the weather pack connectors and can make a shut plug).
The fan should then operate as depicted in the earlier circuit diagram.
I could get this done before the trip to Bowling Green and install the part when I return.
I would feel much better with this working correctly.
I believe this symbol is for a diode, but have forgotten how to read it, I believe the current flows in the direction of the arrow inside the symbol??? Help??? That does not make sense as as there are arrows pointing in both directions.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
