_1Flyboy
Sep 10, 2019Explorer II
......if you have a Duramax you should have a P/A ( plastic/aluminum ) radiator; VERY efficient; not common to plug up internally but rather the airflow plugs up ( high fin count ).... The big issue is that the plastic tanks crack....If it was ME, I’d have every belt, hose, tensioner, thermostat, water pump, ,radiator, etc replaced & stick with OEM thermostat & water pump at a minimum....if you are happy with the truck & don’t really wanna buy a new one.....There’s some good & some bad aftermarket parts out there...I’m on 2nd Duramax and have some experience in the industry....
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
