the_bear_II
Sep 10, 2019Explorer
The times I have had cooling issues with an older truck it was the fan clutch twice and the thermostat once. I did replace the radiator due to a leak but it wasn't causing a heating issue.
On my daily driver car with a plastic aluminum radiator the plastic developed a crack. I was able to keep up with the water leak for a few weeks while I looked for a replacement radiator. One day while driving to work the temp gauge pinned hot. The radiator still had plenty of water. The thermostat had stopped opening.
So I would check the operation of your fan clutch. It may be coming on but not strong enough under load. And make sure the thermostat is opening or not clogged.
There is a product be RedLine called "Called Wetter Water" I used it in my truck and it kept the temp 20 degrees lower while pulling my 5th wheel up a grade that we travel often. It works as advertised.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
