ice2fire
Apr 22, 2014Explorer
Rain leaking into trailer via AC bolt
Last week we experienced VERY heavy rain while we were stopped. We noticed one of the 4 bolts connecting the outside roof part of the AC to the inside roof had come undone by about 1" ! Due to vibration I guess. Rain was dripping from this bolt. However, it seemed the rain was creeping in under the rubber (?) gasket between the outside roof top and the underside of the AC apron, and then running down the bolt.
I tightened quite a lot (20ft. lbs ? ) the bolt. This caused the drip to slow down/stop.
I have four questions:
Q1: To what torque level should I tension the 4 bolts.
Q2/3: The trailer is 5 years old. Should I replace the rubber (?) gasket ? How difficult a job would this be ?
Q4: Other suggestions ?
Thanks.
Thanks.
