dougrainer
Mar 09, 2015Nomad
Newmar requires 2(two) gaskets for each AC unit. The 2nd gasket, you only use 1-- 14 inch side section. This is the piece that blocks off intake from exhaust. You will see it when you remove the AC unit. Some Newmar Penguins used a 4 inch square gasket around the cold air exhaust port. Either way you will see it when you pull the unit. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
