jrnymn7
Apr 29, 2015Explorer
Then doesn't it make sense that the 100a fuse blew moments after the genset fired up, causing the solar controller to be connected to the panel array only, thus damaging the solar controller, which in turn stopped regulating/bucking the voltage? And if so, I would not expect there to be any collateral damage, seeing as there would be no power from the batteries to the 12v distribution once the 100a fuse blew, and only the bank would see that 19.6 volts.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
