past-MIdirector
Feb 26, 2014Explorer
You have the same hot lead to both hot legs!! If you have 120 on each side to neutral and 0 across the hot legs which do not touch since they are 120 volts each. You either have a problem at the receptacle which has a hot lead disconnected and jumped or someone was messing in the breaker box and both leads are not connected to the breaker properly!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
