msta999
Apr 23, 2021Explorer
On mine there is just two small bolts that have to be loosened to adjust the choke to where you want it then retighten. Does yours have a bi metallic coil spring that activates the choke plate?
Mine does have 2 small screws, I can only see the heads, that look like they are attached to the choke mechanism but I can't see inside the plastic housing and the choke does not move at all when cranking. I may have to take the cover off to see it, but it would be nice if I could find a manual for it.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
