Have a 2012 Open Range 5er. My 12volt works on my landing gear and my slide outs but no 12 volt lights, water pump, awning and the fridge wont fire on propane (AC is fine on everything.) Brad
Thanks all, I will check the converter/inverter for a circuit breaker button. I did check the two 40amp fuses and they were fine. Battery isolater switch is ok as the slides and landing gear worked fine.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
