BarryG20
May 02, 2023Explorer
The air cools and creates a vacuum. Some freezers do have an equalization valve to help prevent this some don't. You might be able to use your finger to lift the door gasket enough to break the seal and relieve the vacuum (as mentioned above a screwdriver would work but you may risk damaging the gasket with it).
That wooshing sound could also be air leakage from the gasket not sealing very well sucking in warm air and then condensing and freezing the gasket to the
freezer making it hard to open. As soon as you open it look for ice or even moisture along the gasket and opening. That might give you an idea of where the gasket is potentially bad.
If there is an equalization valve it could be frozen, damaged or otherwise inoperable.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 02, 2026
