Guardian78
Jul 28, 2016Explorer
I believe it is a Chevy Chassis with a 7.4 Engine, I can only assume the year is the same as the rest of the RV however that I won't know till I am able to get over to my RV and look.
Since we did replace some bad fuses at the same time as the other stuff when I get to my RV I will try YC 1's suggestion and see if it works first, because I did notice even when the engine was off and all the doors were closed that some of the lights near the dash stayed on like the power step dash light and another light that I had to unscrew the light bulb from so it didn't drain my battery.
Won't be able to try it until tonight so keep the suggestions coming so I can try multiple tonight if his doesn't solve it.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
