Guardian78
Jul 28, 2016Explorer
Yeah the coil wire (pink and green if I remember correctly) right where it plugs into the spark plug area is the wire I have to unplug every-time to get it to finally turn off.
So if that means it is a fuse issue what is the best way to test this?
Turn the engine on, then put the key back in the off position, and then just start pulling fuses until it finally turns off?
Any particular fuses to try first? Should I start with the fuses under the hood or the ones under the dashboard first?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
