sidst
Aug 19, 2005Explorer
bassman1 wrote:JPearcy wrote:mrwizard I did read the users manual before I hooked the 4 prong plug up, you can split the 220 to 110 but maybe you split the power in doing so thanks
If you want 110 volts at 30 amps you might consider something like the ELM-3600SS which has a 220 volt 30 amp outlet that breaks into two 110 volt circuits, which could be used to backup a house for example, though this is still a small unit.
Look at the outlet shown on the ELM-3600SS at http://www.eliminatorusa.com/merchant2/merchant.mvc?Screen=PROD&Product_Code=E13&Category_Code=GGEN
The 4 prong plug is 120/240 volts and you're only getting 1/2 the available current in the plug at 120 volts. The generator coils will have to be rewired in parallel rather than in series to get the full wattage at 120 volts.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
