Heir_Max
Feb 10, 2015Explorer
Doug, I can tell you have been there, done that. Long story why it has to come out. I have been making out with generator and roof air when needed for about 5 years now. Do you know if the plastic cover can be cut, slide the coil out, replace, and then repair the plastic cover easier than removing it. It is definitely no easy way. I was thinking about trying to remove the dash cover inside and come down from the top. Would that work?
Jerry
Jerry
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
