jmf27614
Jun 14, 2020Explorer
The compressor shut off after a few hours this time. Restarted the A/C several times, ran the fan on high, turned the thermostat down - couldn't get it to run more than 2 minutes. Disconnected the freeze sensor, same result. So, I ran the heat pump for about 2 minutes. It did not stop when it reached the set temperature, so I bumped it down more and I finally had to shut it off. After that, the A/C worked fine. I don't see any freezing going on - but there does seem to be a thermostat issue of sorts. I'll probably call Thor and Dometic tomorrow to see whether they can shed light on this.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
