Dingy941
Aug 06, 2019Explorer
MrWizard wrote:
sounds like the generator is over heating
used the oem generator compartment
did you add any fans for cooling to the compartment
are you running it with the compartment door open for extra air/cooling circulation
in the previous RV-ClassA DP, in order to use a portable generator
i installed a sliding tray/drawer
and mounted the genny on the tray
slide out to use, slide back in to store
made it easy to service, and allowed maximum fresh air cooling
Nice try, lol, I did install two fans to help keep it cool and extended the exhaust outside the RV. I’m about 99.999% sure this isn’t a problem with the generator running/overheating/etc.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
