mitchmitchell16
Oct 02, 2019Explorer
opnspaces wrote:
Never tried it but I don't see why it wouldn't work. I'll bet you can use the same sensors and just add the second set of wires to them.
Another idea would be next time you use the Tornado to fill the tank have your wife time how long it takes. Then subtract a minuter two from that time and set a timer on your phone. As long as you have a decent charge in the phone and you remember to start the timer things will be good. The timer won't get distracted and when it goes off you just pull the dump valve.
My plan is to splice into the wiring harness and see if that works -- if not I may have to wire directly to the sensors like you suggest.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
