Streff
Jun 25, 2013Explorer
Thank you for the comments/suggestions.
The fan does not run at all. But it does turn by hand. So all it probably mean is that the motor is not stuck.
I will go back up in the roof and check carefully if the part mentioned above is damaged. Thank you for the tip. It's raining right now though.
What about a bad capacitor. I hear folks talking about that as a common culprit. Would that disable the fan from working?
Simon
Simon
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
