N8GS
Sep 02, 2017Explorer
brulaz wrote:time2roll wrote:
So get a battery warmer.
That is the solution.
As these batts are usually installed in the warmed part of an RV anyway, it shouldn't be much of an issue when boondocking and propane heat is available.
It's when travelling in sub-zero weather that had me wondering. N8GS's solution sounds right: insulated battery box with 12V heater run off the truck's alternator or something similar.
And when putting the trailer in cold storage with no heat, just isolate the batts from any charging source, or loads.
It does make things more complicated ...
I have a schematic (ladder logic) of the wiring for my batteries, Converter, battery monitor, inverter, battery heater and the dual coil latching relay that shuts everything off remotely.
I have pasted a copy of it to the bulkhead in the battery bay in case I ever need to troubleshoot something.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
