PJ4284
Apr 29, 2019Explorer
dougrainer wrote:
The BLUE wires just send a 12 volt signal to the furnace to ACTIVATE the furnace to heat. Once the Blue wire sends the 12 volt signal the Fan relay is energized and the motor should come ON. NOTHING will happen until the Fam motor runs. So, you need to jump the 2 blue wires AT the furnace, not at the Tstat. Also, ONE of those blue wires must have 12 volts positive. So, IF you have no 12 volts at either BLUE wires that is the start of your problem. The blue wires start at your furnace and the Furnace supplies one of those Blue wires with the required 12 volts. It makes no difference which blue wire has the 12 volt power, just one of them. Doug
Hey Doug, Thanks. I did connect the 2 blue wires at the motor. I put in parentheses Tstat because I was told the 2 blue wires at the motor called it system to heat and the motor would kick on. Anyways, After connecting the 2 blue wires nothing happened. One blue does have 12 volts. When I take the red wire to fan motor and connect it to the same terminal (as the blue that has 12 volts) on the relay the fan will kick on but I do not hear any clicking like it wants to ignite. When I put the red back on the relay where it is suppose to go and reset everything nothing happens. Of course I do not have the propane on at this point.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
