Chevyman2006
Oct 22, 2016Explorer
dougrainer wrote:
1. You had a LP problem and a stove problem. WHY would they even touch the refer?????
2. Maybe YOU did not get the refer secured and when they did indeed operate the slide the scenario you listed happened? That makes it your fault. BUT, the tech should have called his supervisor and showed the problem and they then called you. Not just shove the parts inside the refer.
3. I fail to see why they have to replace the refer. Just the doors where damaged?
4. THIS WHY IT IS IMPORTANT TO ALWAYS GO INSIDE AND AROUND YOUR RV WHEN YOU PICK UP THE RV. DON'T HAVE TIME? BS. YOU CANNOT SPEND 5 MINUTES DOING THIS? Doug
I delivered the camper with slides closed and fridge secured. What they do while it's on their property is their responsibility.
They said frame of fridge is bent.
I should have checked it better and usually do, but we were headed out on a trip and it was 1630 and tire shop closed at 1730...didn't have much choice b
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
