paulm999
Jun 27, 2014Explorer
Problem solved, after a little more head scratching. Like I said, I've been able to turn off the compressor by dialing the t-stat to the warmest settings. I thought if I didn't ever find a switch, this extra step isn't too much bother. Then I woke up to 56 degrees in the trailer. Seems the t-stat didn't cycle off/on at it's minimum temp of 68*. That's when I got to thinking I have more of a problem than the selector switch. Maybe the t-stat is gone the same way as the selector switch. Maybe that large relay by the capacitors (that's there only for the capacitors.) Actually, what was happening is the selector switch was going from bad to worse and now affecting the t-stat. I found an exact replacement switch and traveled the 120mi RT to get it for $32. Leonard Howell, who I thought left the RV appliance business 10 years, is now working out of his home with about $67,000 worth of parts. Leonard's been doing RV appliances longer than most of us have been alive. I think he's 90. He assured me that all the troubles I've had with the old AC are because of the selector switch. Right he was. Just got the AC back together and it's working perfectly. So, if anyone has an older RV and needs old obsolete parts, this is the guy to call. His number is on his web page. He is located in Lakeside, California, which is pretty close to Santee Lakes Campground.
http://howellsrv.com/
Having RV issues? Connect with others who have been in your shoes.24,332 PostsLatest Activity: Nov 05, 2025
