jfeltham
Jul 27, 2018Explorer
dougrainer wrote:
On Jayco, there is a 30 amp ATC fuse. This fuse is between the Battery and the INSIDE fuse panel. It is located in 2 places depending on the Year Jayco. On a short pigtail within 10 inches of the POS post of the battery. OR, on the front of the trailer ON the cross frame, there is a 4 by 4 metal box and coming out of that box is that 30 amp ATC fuse. IF that fuse is blown(it is) replace it, Your problem is solved. Also, if that fuse is blown, your truck will not charge the battery in transit. Doug
30 amp fuse on POS line is good.
So strange. everything works as it should when connected to 115v.
Shut off 115v and connect the battery, and all 12v stops working whether or not 115v is connected.
Follow-up question...what is the Yellow line on the NEG cable? It has a 35amp in-line fuse. When connected, it gets very warm.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
