sdmotor
Dec 17, 2013Explorer
Everything is connected and working as it should. The only odd thing I noticed is that I cant put the converter into the lowest setting using the button on the remote, I only get med or high. My guess is because the solar controllers float setting is higher than the float setting on the converter. I think the PD9100 series is 13.2.or 3 and the solar controller is 13.6. Maybe at night when the panels aren't producing it might drop to there. Other than that it seems to be working as intended. I also noticed that when I unplug the converter and or shut the main off the remote light still flashes. I measured the amps coming in and got 10.5 which seems right given the flat mounting and the winter sun I'm getting.
Thanks again for the input!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
