fourboysdad
Aug 19, 2014Explorer
Artum Snowbird wrote:
Here is what I think. Your converter is putting out full output. It's not getting to the battery. Put your multimeter on the converter output terminals and see what it says. It should say 13.7 volts. Put your multimeter on the battery. It should say the same as the converter output terminals.
If the two do not have the same reading, either the negative or the positive to the battery is loose. Run a jumper cable between the battery positive to the converter positive. Did it fix it? No? Run the jumper cable from the battery negative to the converter negative.
Hot means working hard. Not broken.
Thanks. Ok, dumb this down for me if you would:
What makes you think the converter is putting out full output? I don't know how to tell.
I'm sure the battery leads are tight and cleaned. I will recheck the voltage tomorrow morning.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
