Yá'át'ééh; (Hello) I've posted this on a couple of other forums a few months ago and only found 1 or 2 RV owners with similar setups. Hoping there may be some on here. Keystone has modified ...
On my new 28RDB, I have the same dilemma as the OP. Milo, did you find a good solution?
I'm going to try to rig up a short hose that threads into the intake and then I can attach to a spout to add in water--think of a very big water bandit type thing. What I don't know yet is whether the water will have enough force pouring in to go past the petcock valve inside. If not, then I will try one of the pump solutions.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 25, 2025
